dougrainer
Nov 24, 2014Nomad
doxiemom11 wrote:
Our Monaco does doug. We can use either of them for the furnace or for the AC. For the AC - the AC in the bedroom is controlled with the bedroom thermostat, and the one in the living area controls the AC in the living area. Both thermostats are identical with on/of, heat/AC and a temperature setting and a fan only setting with hi/lo choices. They are Dometic thermostats. We have used either/both for the furnace so we know for a fact that they work that way.
Then you have 2 furnaces. You cannot and Monaco never wired 1 furnace to 2 tstats. OR, you have an Aquahot system, which is NOT a furnace. Some OEM's installed the same model tstat in the bedroom and living room and even tho they state Heat, does not mean that they control the furnace. Doug
38,776 PostsLatest Activity: May 14, 2026
