Coach-man
Nov 22, 2014Explorer
Two things can fill your tank, first gasoline, the second is air, which contains water vapor. When it gets colder, the air can not hold as much water vapor, so the water vapor turns into water, and mixes with the gas! Gas and water do not mix well, you get rust, corrosion, and gum, talk about gumming up the works! When not running, keep your tank as full as possible when in storage, this will limit the amount of water that can get into the system!
