Ted66
Oct 31, 2014Explorer
Chris, I just went though something similar with my Leisure Travel. I thought for sure it was the window as well. Eventually I determined that it was where the water heater mates up to the body of the RV (on the inside seal)just UNDER that same window. In hindsight, I could have (or should have) done a better job of ruling out specific areas.
Case in point; you can take a section of plastic (even a larger garbage bag) and completely seal off the exterior of that window with duct tape and the plastic. Then turn your hose loose on the RV. If it leaks no more, then it's the window - continue to work on it. Otherwise, time to move on to the next section to completely seal off, perhaps the mounts for the rack.
Good luck!
Good luck!
38,769 PostsLatest Activity: Mar 31, 2026
