mama_sylvia
Oct 21, 2017Explorer
So I can at least ask if the mounting bracket can be moved higher if I can find a competent installer. (This was NOT the only problem with the installer's work, there were 3 things to do and every one was screwed up.) I suspect the answer will still be no as the step looks right against the bottom of the coach when folded.
It had a manual 2-step when I bought it. The bottom step kept bumping against the ground, which is why I thought a 1-step would work better. Maybe I need a 1-1/2 step. lol
38,769 PostsLatest Activity: Jun 25, 2013
