Ed_Gee
May 13, 2022Explorer II
Grit dog wrote:
Just get a mounted spare and figure it out. And no, normal tow truck drivers don't dismount tires on the side of the road. If you can't figure out how to carry a tire on a rim, and have a flat, be prepared to sit for a while. Or get tire mounting tools, if you're going remote. And they will weigh as much as a rim. Or more.
I can't believe a Transit doesn't come with a spare... That's crazy.
Btw, if you can trust your ladder to climb it, it will hold a little tire and wheel that size.
The Winnebago Fuse 23A on the Ford Transit 350 diesel chassis has the generator mounted under rear where a spare tire would normally go. Regarding ladder specs, the climbing weight is for static weight.... when RV is not moving . Forces exerted while moving over bumps, etc. can be far greater on mounting screws can be much greater..
38,782 PostsLatest Activity: Sep 10, 2026
