Dachristianman
Dec 20, 2014Explorer
Kidoo wrote:
I wonder if you can back up with a toad 4 wheel down? At least a little?
Thanks
I believe you can, a little.....but define "little." I backed up once until the toad went caddy-whompus. I then disconnected everything to get out of the tight spot I had put myself in.
Could you damage something? Sure. Could you get lucky? Sure. I think the best advice is to keep an eye on your steering wheel. As long as it remains centered, then there shouldn't be any different stress on the tow bar than when stopping (as mentioned earlier). Your pivot point of the front tires will be the first thing to turn. Once that happens, all bets are off on where the next stress point is located on the setup.
Tom
38,782 PostsLatest Activity: Sep 10, 2026
