SJ-Chris's avatar
SJ-Chris
Explorer II
3 years ago
Can you name that sound (squeaking)?
I have a 2013 Coachman 210qb Leprechaun Class C. It has a Ford v10 e350 Super Duty engine. It has 111k miles on it and it hasn't been giving me any issues until now. It has recently started making a squeaking/rubbing noise that I cannot identify. Looking for suggestions....
Here are the symptoms.... After sitting parked for many hours/overnight, when I start it up and start driving there is a rubbing/squeaking noise that starts at about 15mph and continues up to about 40mph. Once up to about 20mph, the noise happens while accelerating, and/or while coasting, and/or while braking. It doesn't matter what gear it is in. The sound stays constant between shifting gears and also if applying a slight pressure on the brakes. After about 1.5 miles of driving, the sound goes away and it doesn't happen again until the car has been sitting parked for many hours (or overnight).
It sounds like something is possibly rubbing (brakes??) during this time and I suspect it has something to do with the rotation of one or more of the wheels. To me, the squeaking noise sounds like it might be related to the tires rotating (...the noise is kind of rhythmic and the speed of it seems related to how fast the car is going). Maybe it goes away because something has warmed up after 1.5 miles???
I did one additional test. I let the RV sit overnight. In the morning, I turned on the car and let it idle for 10 minutes so that the ENGINE itself was warmed up. I thought maybe if the sound is going away once some component of the ENGINE is warming up that I would be able to do this test (get the engine warm and THEN drive it...maybe I wouldn't hear the noise). But when I drove it I got the same noise (rubbing/squeaking) starting at about 15mph for about 1.5 miles and then it once again went away.
Here is a video where you can hear the noise. Turn up your speaker. In this video, it starts at about 2 seconds and goes away at around 8-12 seconds.
https://www.youtube.com/watch?v=XZz_NoQntB0
(Note: The "D" (drive) flashing in the video isn't real...it doesn't flash/blink like that. For some reason it just looks that way in the video)
Here is another video where you can hear the rubbing/squeak louder right up to about the 20 second mark.
https://www.youtube.com/shorts/2VmWOJROS-s
Any thoughts?
A friend of mine who is mechanically inclined thought it might be the "indicator clips"(?) of the brake pads making the rubbing/squeaking noise. I'm not convinced that is the issue since the noise is happening NOT because I am braking...it just starts making that noise once the vehicle goes from being cold started and then gets to about 15mph. Could indicator clips cause/behave something like this?
"indicator clips" are the small clips on the brake pads that will hit the rotors (and make noise) before your brake pads get too low.
Let me know what you think.
Thanks!
Chris
