Gjac
Dec 04, 2022Explorer III
Chris your u joints and carrier bushing looks good, you can put a wrench or socket on a breaker bar on the tensioner pulley and remove the belt or just relieve the tension and wiggle each pulley to see if there is any play in them. Also you asked earlier how to check the break squealers, sometimes with out wheel liners or hub caps you can see them with a bright light and a mirror on the end of the break pad. Also if the pads are thin say a 1/8 or so they could be rubbing. Taking the tire off to check to check is not that hard either. While it is jacked up you can wiggle the tire to check you wheel bearings also. Good luck.
