ncrowley
Dec 12, 2014Explorer II
Thanks for all the replies. To clarify - we tested at the plug in the back of the motorhome. We grounded the tester well and looked at each of the pins on the plug while we had the right blinker, left blinker and headlights on.
The blinkers and the headlights worked fine on the coach. However, there was no voltage on any of the pins when the right turn signal and the headlights/tail lights were on. We saw voltage on the correct on the correct pin when the left turn signal was on. Therefore, there is something wrong in the coach.
We will look for a converter and something around the cockpit. So far, we have not found any panels anywhere around the cockpit either inside or outside. We will also listen for a repeated in the battery compartment.
I will get back to all of you with the results.
38,782 PostsLatest Activity: Sep 19, 2026
