FIRE_UP
Dec 12, 2014Explorer
ncrowley,
So, does your "black box" with the trailer plug fuses look like the the one in my pictures I posted, minus the lettering "Trailer Plug Fuses"? I did that with my Vinyl sign making machine. Also, does the "aluminum" part that you found next to your "black box" look like the one in my picture? If so, it's the Allison Transmission Controller. If it's what and where I think, your coach and ours are different makes and models but, they both have Freightliner chassis's and, Freightliners lay-out of where and how they place things, looks like it can be somewhat similar.
My fuses, as stated, were/are under a panel, at the very left rear corner of the coach. I have to unscrew a couple of screws and hinge that panel upwards to see that fuse panel for the trailer plug. While yours, is in the Inverter compartment which, on mine, is right in front of where the panel I lift, to get to the fuses.
Glad you found them and were able to move along with this issue. Good luck.
Scott
Scott
38,782 PostsLatest Activity: Aug 11, 2021
