MrWizard
Jun 07, 2019Moderator
i don't need a MAP
i don't have these codes
MAP trouble codes:
Code 22: MAP Sensor Out of Range.
Code 72: Insufficient MAP Change During Dynamic Response Test.
Code 126: MAP/BARO Sensor Higher Or Lower Than Normal.
Code 128: MAP Sensor Vacuum Hose Damaged or Disconnected.
Code 129: Insufficient MAP Change During Dynamic Response Test KOER.
i thought i might have a MAF problem
but this doesn't a MAF
so i investigated the MAP
MAP trouble codes:
