rk911
Apr 20, 2017Explorer
dmctlc wrote:
Well folks made the plunge today more than I wanted to spend brought my first CLASS A Motorhome new...finally out of the TT but I'm sure it will be worth it to travel with during m upcoming retirement. So the question to all I'm looking for the best system to tow my 2017 Lincoln MKZ Hybrid. Any suggestion out there I'd appreciate it. I've hear a lot about the Blue Ox but I see it requires an extensive disassembly and cutting of my front end of the new car which I'm sure would void the warranty. Having the RV dealer do the installation won't guarantee it will be done right either. And I'd hate any electrical issues with a Hybrid. Any suggestions other than getting another car to tow? Thought of a car hauling trailer not familiar with that either and with the car and trailer I'd go over the 5K towing I'm sure.
the first question is CAN you flat tow your Lincoln? if it can be flat towed without modification to the tranny the next question will be what does it weigh? just because you have a hitch capable of towing 5K doesn't mean you can actually tow 5K.
in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configured for travel before choosing a toad. but you're already there and you still absolutely need to know. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
you won't be able to make these calculations and know for certain whether you can tow your Lincoln until you load the MH as you would for a typical travel day and then get, at a minimum, individual axle weights and then do the arithmetic.
what I would suggest is what I've done with all 3-motorhomes that we've owned.
- get an actual empty weight (each axle) of your MH. minimal fuel, no water in any of the tanks, no or minimal LP, no food, supplies, etc. basically the way it came off the mfg assembly line. do not trust their empty weight. know what YOUR MH weighs.
- get a wet weight. fill the fuel, fresh water and LP tanks and re-weigh (each axle).
now you'll not only have a base (empty) weight but after the wet weight you'll know how much weight you can add to each axle before being overweight on either. if before or after the next step you end up close to the GAWR for either axle you can adjust by off loading some fresh water (8lbs per gal).
- now get a travel weight by keeping the water, LP and fuel tanks full (or whatever load of water you determine you can carry) but also loading up food, clothing, supplies, pets, people and other stuff. re-weigh each axle. basically the way you intend to travel.
then do the calculations I listed above. then and only then will you know for sure if you can flat tow your Lincoln. if it turns out you have to dolly or trailer your Lincoln you'll know the answer by adding the weight of the dolly or trailer to the weight of the Lincoln and then doing the arithmetic.
good luck.
38,771 PostsLatest Activity: Apr 22, 2026
