Dale_Traveling
Apr 20, 2017Explorer II
The Ford published owner's manual does provide instruction for recreational four down towing so you don't not need to modify the powertrain in any manner. But without adding a base plate your options are a dolly, trailer or find a beater to modify and tow four down.
Looking at the installation instructions for a Blue Ox base plate I'm at a loss to find anything that might impact the mechanical systems of the vehicle. Pretty much any based plate is going to involve disassembly of the front end clip and some modification of the structure behind the clip. Installation isn't difficult for a confident mechanic or body tech but any shop is going to charge several hundred to do the work for the labor time.
The Blue Ox recommended power for brake, turn and driving lights from the coach is diode based and although involves splicing into the wires at the lights I can't see how it could be a warranty issue also considering it will be very easy to remove and return the circuit to original if necessary. You could bypass the mod by using magnetic lights on the trunk lid.
Up to you as the owner. If the warranty issue is flashing in your eyes then find a dolly and hit the road.
38,773 PostsLatest Activity: Apr 22, 2026
