FIRE_UP
Apr 23, 2018Explorer
Tom/Barb wrote:FIRE UP wrote:
Tom/Barb,
I have done exactly what you're thinking about. The coach we did it with at the time was a '99 Fleetwood Bounder 34V with the F-53 chassis and the 275HP Triton V-10. The V-10 had the Banks kit on it when we bought the coach. We'd towed Jeeps all over the planet for years and had zero issues with three different coaches, up to that one. But, I acquired two TW 200s and wanted to take one with us when traveling.
So, I built a hauler for it, to be attached to the receiver of the coach. While it was a tad crude for my normal fabrication, it worked, and worked very well. I designed it not only for carrying one TW, but also to tow our '04 Jeep Rubicon. It was a good system all except for what it took to get the bike up on to the rack and back off. That rack was a bit high for manual loading of the bike and, it was impossible to ride it up. But, we did it and survived.
Since Photobucket robbed us all of being able to post pics, I can't show you the system. It was not hard to build. One thing you want to make sure of, (there's actually more than one) is, making sure you have adequate tie-downs for the bike. You don't want that bike rocking around.
Scott
Thanks for that, we know that the longer the rear over hang is the easier to exceed the turn radius of he Jeep, and we are pretty long now.
There is no easy answer, But we know the trailer hitch on the jeep will not carry the weight with out major modification.
Not exactly sure what you mean by that. When I built my carrier, as stated, I also welded in a receiver so we could tow right from that carrier. The receiver was of normal length. And, the tow bar, inserted into it, just like normal. When I first set the system up, I hooked everything up and the wife and I cruised on down to the local high school parking lot, just down the street from our home.
There, I had her turn the motorhome in tight radius turns, from straight to left and straight to right. At no time, was the Jeep ever in danger of colliding with the bike. It just went to a certain distance between the two and, from that point on , it just followed that distance 'till we straightened out again.
It's tough to find a commercial made hauler that will also tow, without getting in to VERY BIG MONEY. As in, a Hydralift or Cruisemaster or, Overbuilt. And you most certainly don't need anything like any of those for a 275 lb. TW 200. That's why I built mine. Sure wish I could post pics. I can do it on any other forum, just not this one.
Scott
38,769 PostsLatest Activity: Apr 03, 2026
