Chris_F
Jul 20, 2014Explorer
Information on how the OCCC is reported can be found in the Introduction section of the Vista manual, which you can download from the Owners section at gowinnebago.com. Apparently your salesman doesn't read manuals for the products he sells.
There is no practical way for Winnebago to publish OCCC values because the numbers depend on the options installed. Calling customer service will not result in the right number unless you specify exactly which options are installed. Did you note the 4255 pound number I mentioned for a 35B? I've got a photo of a label from another 35B that shows 3930 pounds because it has a slightly different set of options. The weight difference is roughly equivalent to a half tank of fresh water.
