pulsar
Jul 24, 2014Explorer
rk911 wrote:pulsar wrote:
The OCCC for a new coach will be on a federally required label, which can be found in the drivers area near, the vehicle certification label. Sales people I've talked with, don't know the label is there.
On edit:
OCCC = GVWR - UVW - propane
UVW is the weight of the motorhme as built at the factory with full fuel, engine oil and coolants
Water and occupants count as cargo; propane does not.
Sources: 49 CFR 571.110 as found on www.law.cornell.edu
Tom
all of these new weight ratings (OCCC, UVW, etc.) are, in my opinion, designed to confuse. I prefer to consider weights and weight ratings this way. GVWR minus the actual unloaded weight of the MH (nothing in it that didn't come from the factory or added dealer options) equals the payload. and one needs individual axle weights to determine not only how much payload the MH has but where it is located.
First, UVW is not new; it has been used by the RV industry for as long as I can remember. It was used in the original CCC definition that came out in 2000 and it was used in the NCC definition that goes back much further. UVW is identical to curb weight that has been used by the automotive industry for even a longer period of time.
It appears that you want to use the dry weight, which doesn't include fuel, oil, nor coolant. I think it unrealistic to think that the majority (let alone large majority) of RVers would calculate the weight of the fuel, oil and coolant as part of their cargo. Do you really think that RVers should calculate the weight of those fluids as part of their cargo?
Because I understood it, I didn't mind the old CCC. But I will admit the sleeping position part of the calculation would cause a problem for many, if they were trying to calculate how they could "fudge" by having fewer occupants.
The newer OCCC accounts for what is not really flexible. GVWR - UVW - propane, assuming that all RVs will need to carry propane and that is not likely that many will ask for a partial fill of their propane tank(s).
Recognizing that many RVers don't have as many passengers as the RV could carry and that an RVer may choose not to take a full tank of water, the OCCC definition places water and occupants in the cargo category. In that light, the regulation requires that how to calculate the weight of the water is on the OCCC label that is required to be posted in the driver section of the coach.
In the end, I believe that all RVers should have their rigs weight, preferably each wheel separately, after they have loaded it.
Tom
