slickest1
Aug 07, 2017Explorer
The harder you are pulling the more heat it will build. It may hold at a certain speed climbing a hill but if it is lugging along at a lower rpm it will build more heat. When in very hot weather it adds to the problem dramatically. Shifting down alows it to pull the hill easier and not build as much heat plus your fan is cooling better at the higher rpm.
