Rolandh
Jun 16, 2024Explorer
Randy. Were you able to fix this problem as I have one that has the same issue?
- bid_timeJun 16, 2024Navigator
Randy hasn’t been on here in almost 10 years so it isn’t likely he is going to respond to your inquiry. However, if you would have read down through a few posts you would have found that Randy changed the air filter and it solved his problem.
- RolandhJun 22, 2024Explorer
Thank you. I asked the question before I signed up so I couldn’t see dates or other post
38,782 PostsLatest Activity: Sep 10, 2026
