- golfknutExplorerThe sticker was on the backside of the cabinet door over the kitchen sink.
- dumboat2ExplorerGolfknut, where did you find the sticker?
- dumboat2ExplorerThat is what I needed, thanks. Jerry
- golfknutExplorerWe have an '05 3100SS.
The sticker on ours shows a UVW of 12,451 lbs.
And a GCC of 1,598 lbs.
Minus full fresh water, LP gas, and 4 adults the resultant CCC is calculated to be 544 lbs. - Mich_FExplorerThe Ford van under that motor home was rated for 14,050#. I'd guess the vehicle weighs around 11- 12,000#, so I imagine you're somewhere around 2,000 - 3000# CCC. The only way to know for sure is to weigh the unit.
- dumboat2ExplorerIt is the 3100 ss, so31 feet. No sticker, already looked. Archives gives the GVWR only. Even got in contact with Jayco and they never responded.
- GrumpyandGrandmExplorerThere should be a sticker on the door under the kitchen sink or in one of the cabinets.
- triple602ExplorerCheck Jayco site under Archive
- Mich_FExplorer
dumboat2 wrote:
Anyone know the CCC rating for a 2003 Jayco Granite Ridge?
It might help people help you, if you mentioned what size MH you're asking about.
38,780 PostsLatest Activity: Jul 05, 2026
