Ivylog
Sep 30, 2018Explorer III
13 years ago when G4 LED were almost $3 I replaced all of my ceiling halogen with 32 led bulbs...went from 36 amps to 4 with all on. In those 13 years I had to replace 2. I recently replaced over 70 in my "new" ride at less than $1 each. I like the 5050 chip size and the link below will let you measure if you can put a 15 chip led or even a 24 in your puck. Most of mine were only big enough for a 12 chip bulb after cutting some of the leads off so they are centered in the puck. If under a cabinet I would not worry about them being centered...more chips equal more light. I now like the warm white closer to 3500 temp the best for inside use. Buy a couple of each size and SEE how you like them...won't be out much.
.....Various G4 5050 LED
