Kidoo's avatar
Kidoo
Ceiling hanging a little - How do I fix it
Hi, the ceiling of my Cayman is hanging about an inch in the middle at the trim above the seats. I can push in the trim with my hand and the hole ceiling goes up.
How can I fix this? I was thinking at putting a screw or two and putting a snap cover over the screw.
  • You could do the screw idea with the snap cover as you stated. If you look around, you can probably find a snap cover that is a good match. Then install them evenly across the seam so it looks factory.
  • gptta find out why. sounds like you might have a roof leak ,OR it just came loose from its mounting. if you can take a section down and see whats going on. they do make spray glue in a can that shoots about twoft stream.
