jeremywatco wrote:
Executive wrote:
That small candy bar INSIDE antenna works well depending on how you use it. We simply place the mifi ON TOP of the candy bar and can use the wifi anywhere in the coach. It will work the same if you use your phone as a hotspot.....Dennis
My only concern at the moment is I may have the booster way to close to the antenna. I'm hoping that the roof and cabinet are enough to block the interference. I'd hate to drill a hole in the vent and not use it.
Run the wire down and try it our BEFORE you drill the hole and/or mount the MaXXair cover. If it works as you want, THEN drill the hole and mount the cover....Dennis
