Leda
Jul 08, 2016Explorer
Regarding water pump I found the pressure adjustment but it didn't change anything. I turned it 3 times with no visible change to be seen. So now I have decided to clean the filters but before I do so shall I drain the whole water tank?
Something else maybe important to mention - when I turn the cold water on it is slow but it still flows, but if I turn the hot water on it barely flows, almost drop by drop...
Also, shall the water pump turn off from time to time? I mean as soon as I turn on the button for the pump it works without stopping till I turn it off. In my old motor home it was working for a while and then stopping by itself as soon as you do not use it. Before you ask - I have checked for leaks in order to find if it is losing pressure because of leaking somewhere but no leaks where seen... it seems that it is losing pressure and that is why it is not flowing as it should as well as it is working all the time to make up for the lost pressure... but how and where?? Any guesses and suggestions what else to check?
Also, the generator works and is charging the batteries but I don't have power in the plugs and the microwave is not working as well... maybe there is a switch that makes it gives power to the plugs and appliances? It does not seem to be automatic... any tips?
Last but not least especially in this weather - I read in the manual that air conditioner can work either with generator or with external power source. So can I use it while driving? And as I can not find how to give power to appliances from the generator I can not use it for now... help please. THANKS SO MUCH!
