ccxnola
Sep 19, 2015Explorer
For the ceiling, the tension in the bow of the roof held it in place and I put in small screws under the trim for the light fittings, a/c and along the sides - covered by the trim pieces.
On the walls, I used brass screws - placed as would happen with a wood panel (not aligned with the plastic panel, but rather as would look like an actual wood siding). I used trim strips of actual cedar (buy the cheap fence pieces - cut and plane them) for around the sides, windows and base (screws under the trim). And it does have a very pleasant cedar odor - if you like the out-of-doors.
38,769 PostsLatest Activity: Dec 31, 2014
