Dstrahm
Aug 27, 2016Explorer
Sam Spade wrote:lenr wrote:
Would be shocked if fuel savings would pay for gear change.
And I would be shocked if some layman's gut feeling turned out to be better overall that all of the mechanical engineers who designed and built the thing to start with.
If you think you MUST.....wait until you need tires anyway and get some slightly taller ones.
If you do the gears you are likely to OVER do it and the result will be worse mileage and engine and transmission strain and a MUCH bigger bill in the end than you bargained for.
Sam Spade, it's a bit disappointing to see a Senior Member disrespecting another member, a recent member at that, with such comments.
My dad was a degrees mechanical engineer and worked for GM as an automotive engineer on drivetrains before he moved on to aerospace. I'm a degreed engineer also and have torn down to individual parts and rebuilt just about every automotive system in just about every type of passenger vehicle, including drive axles. To back the axles out and drop the pumpkin and replace with a different ratio part is not a big project.
I am also quite familiar with the engineering work performed during the design and component selection for any vehicle, but I also understand that the choices are based on trying to best meet the needs of a very diverse population of potential users.
My question was to see if there were any others on this board that knew of, or had direct experience with this mod. The tires approach was considered, and may well be the chosen path. My concern was adding height, road to axle and road to frame, and also having to "mental math" the speedo.
I've read quite a few great posts on this board and value the information shared. Let's all remember to keep it positive and respectful. If I misinterpreted your response, please accept my apologies.
38,780 PostsLatest Activity: Jul 04, 2015
