harold1946
Aug 28, 2016Explorer
Dstrahm wrote:
Has anyone changed the differential gears in their MH to a different ratio? Our 1999 Brave is geared way too low for how we use it and my thought was that I'd get better mileage with a higher ratio. Now at highway speeds the engine is running around 2000 RPM and it has enough low end torque to pull stumps easily. I'd gladly trade a slower acceleration off the light for better gas mileage and a quieter running engine. The axle is a Dana model, 80 I believe.
Thanks!
www.drivetrain.com Has all the information on identifying you axle and gear ratios. There is also a full list of available ring and pinion options.
I suggest contacting them. They will be able to give the best advice.
38,782 PostsLatest Activity: Sep 10, 2026
