Johno02
Aug 26, 2014Explorer
Check your owners manual. There is probably a set-up feature to change the reading. Funny thing, our HHR is the same way. it has numbers, and a small light that indicates MPH or KPH. it can be changed as one of the setup options. if I am moving when I change it, the speedo needle will jump from one value to another. The numbers don't change, just where the needle points. The Temperature readings and odometer readings change at the same time. real easy to change, just read the book. BTW, don't bother asking the mechanics at the dealer, they probably don't know either.
