msturtz
Feb 01, 2019Explorer
wa8yxm wrote:
THe only way I'd even consider switching a heat pump for heat to heat strips.
For one thing... A/C's on RV's tend to be roof mount. I want A/C's on the roof as that is the hottest part of the RV.. but for heat I want it down near the floor. Heat pumps DO have advantages that make 'em worth it. but if I'm going to use resistive heat (Electric heat strips) I want 'em near the floor where my space heaters sit...
NOTE: most RV's are not wired to support space heaters. I added heavy duty wiring to mine just for that 12ga wire feeding 15/20 amp outltes wire bent around a tightened screw.. NOT the uni-box **** the factory put in.
Absolutely correct! RV wiring is substandard at best. Small wire size, uni-box outlets, undersized main panels, and so on. Not fun.
