fyrflie
Apr 10, 2017Explorer III
traveylin wrote:
Bumpy is my buddy go easy.. Changing out stop, running lites should be no issue. Left/right turn signals do require sufficient voltage drop to operate the blinker thingey. Leds sometime do not do it
If you have a problem with the blinker thingy, it may be that you have a mechanical flasher that requires a certain amount of voltage to operate correctly.
A simple fix is to switch to an electronic flasher. This is a very common problem on jeeps when switching to LEDS.
What you will notice is that your blinkers will blink real fast.
This is my experience with my jeep , so I don't know if the RV world would be that much different.
