wolfe10
Dec 27, 2015Explorer
You will have to tell us if your average consumption is less than 8 amps.
And, also that the 8 amp charger is a smart one and will not burn up the batteries by overcharging them.
Even if you are OK per both above, they are short term solutions IMO. Either get the inverter/charger fixed or replaced or go with a smart converter (much less $$) if you don't need the inverter function.
BTW, how did you damage the inverter to the point that it needs to be replaced?
38,766 PostsLatest Activity: Jan 10, 2026
