mena661
Apr 30, 2014Explorer
Crabbypatty wrote:It will be more than 300 hours. That last 10% takes as long or longer than the first 40%. To the OP, you don't want to fully charge batteries on generator unless that's your only source for charging (ie you don't have access to shore power). WAY too much fuel to do that. Cheaper to spend a few days at a full hookup campground.
The other question is what is the charging output ? Exp if your 600 amp batts are 50% discharged and your only charging at a 50 amp rate, you need to run the genny 6 hrs. 6 x 50 = 300.
38,776 PostsLatest Activity: May 15, 2026
