Gjac
Mar 14, 2019Explorer III
CodyClassB wrote:Is that the one from HF, if so that green knob on mine loosed up and caused arching, the black burned contacts left me with a no start situation twice before I finally remove it. Now I just disconnect the neg terminal when in storage. As others have said there is a parasitic load, mine is about .4 amps which will drain your battery. I charged mine in Oct and disconnected after almost 6 months it is still at 80% SOC.
Thank you all. I learned my lesson. I recharged the dead battery using the method mentioned above (jump started and recharge) . I also also install the Terminal Quick Disconnect Switch
