ron_dittmer
Mar 14, 2019Explorer III
Gjac wrote:That is why I won't install any kind of convenient disconnect switch. Even though they are designed to handle the amperage, they have a much higher failure rate than if it was not there to begin with. It is much better to disconnect the negative ground terminal on the battery post, especially if doing it just once a year during the "Off" season.CodyClassB wrote:Is that the one from HF, if so that green knob on mine loosed up and caused arching, the black burned contacts left me with a no start situation twice before I finally remove it. Now I just disconnect the neg terminal when in storage. As others have said there is a parasitic load, mine is about .4 amps which will drain your battery. I charged mine in Oct and disconnected after almost 6 months it is still at 80% SOC.
Thank you all. I learned my lesson. I recharged the dead battery using the method mentioned above (jump started and recharge) . I also also install the Terminal Quick Disconnect Switch
Like everything in a motor home, you can add many nice features that introduce more points of failure. I ask myself, which ones are critical, which will be appreciated throughout the RV season, and which offer a rare convenience.
In this case, a total chassis failure is not worth any such risk. You may not think of considering a bad kill switch when you are dead on the side of the road. And if you do think of it, will you be carrying a spare to make the swap on the side of a highway? That feature is not worth the risk to me. The chassis manufacture, nor the RV manufacture leave it out for that very reason which is further cause-for-pause.
