pianotuna
Jul 17, 2013Nomad III
Hi Ronnie,
The isolator is unlikely to damage the inverter.
The OEM charging circuit for my "house" battery bank was fused at 60 amps. I replaced that fuse after the third failure with an automatic circuit breaker and added a 2nd charging path. I used continuous duty solenoids that draw 0.88 amps each when they are active.
Nascarcruzin wrote:
Pianotuna, would you recommend I disconnect the battery isolator to prevent any damage to the inverter?
38,776 PostsLatest Activity: May 15, 2026
