wa8yxm
Sep 22, 2014Explorer III
pianotuna wrote:
Hi,
If you are using flooded batteries check the state of charge with a hydrometer.
Good answer however... HE STATED THEY WERE LIFELINE AGM, so no, they are not flooded batteries, they are starved batteries.
To the O/P: Check your charge profile.. The Xantrex units I know do not do auto-equalization like my Progressive Dynamics does, but... I do not know all that many Xantrex models.
Also, use a volt meter and a clamp on ammeter to double check, You could have a battery going south. Recently (Last winter) I had problems with my batteries holding a charge.. Some searching with a clamp on found one battery was sucking more than it's fair share of current.. Replacement fixed the problem (NOTE to others (not the O/P) If you have two six volt in series.. that is 1 12 volt battery for this post and all other practical situations)
38,767 PostsLatest Activity: Jun 02, 2013
