gb71631
Feb 14, 2015Explorer
Tom/Barb wrote:gb71631 wrote:
The control panel inside the RV shows everything to be working correctly and charging. The voltage that comes out of the inverter charger matches the inside too, but the battery voltage at the batteries don't. There has to be something in between causing the loss.
Remember, the battery voltage will not read the same as the charging voltage until the batteries are fully charged.
Checked the fuse the typical way with a continuity meter.
