gb71631's avatar
gb71631
Charging Problems Freedom 458 Inverter/Charger
Needing help... I have a 2006 Gulfstream Friendship G7 with a Freedom 458 Inverter/Charger that's not charging the batteries.
I have went through all of the diagnostic manuals and everything has passed including the resistance if the 1/4 amp fuse was blown. I have checked the voltage coming out and it's exactly what it's supposed to be, but still not charging batteries.
I can unplug the shore power and plug in a charger to the batteries and they will charge OK with no problems...?
Any Ideas.....?
  • gb71631 wrote:
    Tom/Barb wrote:
    enblethen wrote:
    Don't get confused about the fuse. It is not a small automotive. it could look like this.
    Fuse
    Our's looks like THIS
    Mine looks like the eBay link too. Just got back from checking it as it's right above the inverter and it checked OK.
    The control panel inside the RV shows everything to be working correctly and charging. The voltage that comes out of the inverter charger matches the inside too, but the battery voltage at the batteries don't. There has to be something in between causing the loss.
    How did you check it?
    You must remove it and check continuity or jumper it with a test light while the charger is on.
    Have you worked on the battery pack lately?
    Remember, the battery voltage will not read the same as the charging voltage until the batteries are fully charged.
    Checked the fuse the typical way with a continuity meter.
  • Put in new batteries last year when I purchased the RV. Thought it was just time to replace... now I wished I checked them first. Most likely they didn't need replaced at all...
  • Going to take the circuit light and follow the positive to see where the voltage drop is now and see what's going on...
    Thanks again everyone for your input.
    when doing it that way, you must disconnect one end, other wise the meter will find continuity by some other circuit, take it out, hold it in your hand and check continuity with the meter.
  • You might want to check with the Gulf Stream forum. Many members there with the same type of coach you own.
    www.gsowners.com
  • disconnect the fuse from 1 side. best way to test.
    By the way, if one side of the fuse is high and the other side is low, then it's bad. I am not talking about a few millie volts
