Dale_Traveling
Sep 05, 2012Explorer II
BluesLover wrote:
Date.Traveling- Wow, thanks for doing all that diagnostic testing. Do you think the design is flawed?
Not sure what is happening. We have pretty much identical chassis. The chassis comes from Ford fully operational and the coach builder will add the BCC during house construction. Not really sure what happened. I would expect the alternator to have kept you going down the road. I'm not even sure if you would get a caution or warning light (forgot to check) since usually the failure is the other way around. Alternator failure and the battery running the show, but I've been wrong before.
Design flaw is a bit of much considering the entire Thor F53 chassis based product line are probably identical in DC power layout. Might be a onetime installation problem that was missed by QA. Can't say for sure one way or another.
