Rodallg
Aug 27, 2013Explorer
rvten wrote:
What light stays on?
When you turn off the coach disconnect. Switch and are plugged into shore power. You will get 12 volt from the converter. But it will stop charging your coach batts.
Do you have 2 disconnect. Switches? One for coach and one for chassis?
2 disconnects, coach and chassis, the light for chassis stays on after pushing the switch to disconnect, relay clicks and light stays on. Coach disconnect works as it should.
