Rodallg
Aug 28, 2013Explorer
OnaQuest wrote:Rodallg wrote:
The chassis light on the disconnect panel. I assume that if I tried to disconnect the chassis then tried to start the engine it would not have power to the ignition switch. It will start after trying to disconnect.
2000 Mountain High Pinnacle on a F53.
This is normal for later revisions of the BCC circuit board. Earlier Revs. would not allow starting (would not override the disconnect) if the disconnect had been activated.
Does the light remain ON when disconnect is activated, even when the ignition if OFF, or just if the ignition is on? It actually should go off if the ignition is OFF when the switch is activated.
Is your BCC (the box containing the circuits and solenoids) made by Intellitec or RV Custom Products? I have diagrams and trouble shooting procedures for both if you will PM me.
PM sent.
