bluebarry1964b
Jul 09, 2013Explorer
hooligan wrote:
If you didn't bleed air as you refilled the coolant, you may have an airlock. On my Cummins ISB there are two small lines (hoses) coming from the block near the thermostat housing, they go above and behind the radiator, with a petcock on each. These vent the air as coolant is added. Open those until a small amount of coolant comes out...
Air trapped in the system can cause overheating.
Assuming (hershey is probably right) you did run the heater after refilling the coolant...
I did open the one bleeder that I knew about. The instructions stated to add coolant until some of it came out of the bleeder. Weird thing is, none came out of the bleeder. I'll have to look for the 2nd bleeder... or maybe I should just hand it over to a rad shop and have them redo the whole process.
38,783 PostsLatest Activity: Sep 23, 2026
