Passin_Thru
Jul 13, 2013Explorer
IF you rinsed the engine down or moved wires, check to see if water migrated into one connection and nothing is loose. See Wolfe10s note. After warmup, drive it around some and also, it may take 3-4 ignition cycles to reset the eng ck lite. Smell could be some you spilled boiling off the top of engine.
38,783 PostsLatest Activity: Sep 23, 2026
