dogvetiaExplorerApr 30, 2018check valvesI have a 2004 winnebago Journey 36G. I have replaced the check valve behind the water hearer a couple of time. Today while unwinterizing all was going well after flushing the water heater and lines....Show More
Old-BiscuitExplorer IIIApr 30, 2018Same issue on COLD water ---- low flow/trickle??Or just HOT water??Both Hot & Cold......city water inlet check valveJust HOT......back to the water heater OUTLET
Related Contentcheck valve!!Water Heater Check Valvewater pump check valveWater pump check valve.Check your valve stems!
