dogvetiaExplorerApr 30, 2018check valvesI have a 2004 winnebago Journey 36G. I have replaced the check valve behind the water hearer a couple of time. Today while unwinterizing all was going well after flushing the water heater and lines....Show More
dogvetiaExplorerMay 01, 2018thanks I will continue to look for another check valve. Only affects the hot water outlets.
Related Contentcheck valve!!Water Heater Check Valvewater pump check valveWater pump check valve.Check your valve stems!
