When I took delivery of my new motorhome in May of 2012 it sparkled, but after I had driven it thousands of miles and camped through all kinds of weather my RV had acquired a heavy coating of grime. While staying in a Florida campground in late December, I had a level paved area, good weather, a plentiful water supply and some spare time to give my coach a good washing. My CW dealer in Lakewood, NJ had given me a five-gallon plastic bucket containing some new-customer gift items, including a quart bottle of Camco Wash & Wax. It was time for me to put it to good use.
Following the instructions, it takes only a small amount of this concentrate mixed with water to produce a large amount of cleaning solution. I had a soft, long-hollow-handled brush with a hose connection that would allow me to reach to the twelve-foot-high roof of my coach while standing on the pavement. I dipped the brush into the bucket where I had mixed the cleaning solution, then brushed it onto my coach, washing about a four-foot-wide space at a time. Once I had completely washed a section of the coach with the cleaning solution, I would turn on the water and use the same brush to thoroughly rinse the area I had just washed. It was amazing to see how easily and quickly the road grime washed off. I repeated that process until I had gone all around the perimeter of my 35-foot-long coach. Because of the size of the vehicle, it took me some time, but the results were rewarding. My coach sparkled just like new, repels dirt and I had only used about a half-quart of the Wash and Wax concentrate to do the job.
My results were, in my opinion, a good test of the cleaning, waxing capabilities of this product. My motorhome has a fiberglass outer body with a Clear Coat finish, but I see no reason why this cleaning solution wouldn't work just as well to remove road grime from any car or truck. I might add that the cleaning solution also worked well on the windows and windshield of my coach, leaving them sparkling clean as well.  I later bought a gallon jug of it, which should last me a very long time.
