Executive45
Jun 01, 2014Explorer III
It's an 86 so no crankshaft sensor.
From your description it sounds like you are having a fuel starvation issue. The coach starts up and runs when it's cold but stalls after it warms up. Several things come to mind.
First is routing of your fuel lines. Make sure they're no where near your exhaust manifolds or any heat source. Wrap them if necessary.
Second..are you using rubber fuel lines or steel? Rubber will collapse under hard throttle in certain circumstances.
Third..are you using an electric or manual fuel pump?
Fourth..after it stalls, remove the air cleaner (if its on) and check the butterflies in the carb. Often, after the engine warms up, the spring that holds the butterflies in place is weak and the butterflies will close under throttle. This provides too rich a mixture and will cause the motor to stall. An easy test is to warm the engine, then wire the butterflies open and drive it. See if it stalls. If not, your problem is in the carb.
I don't see it being an exhaust issue as you would experience that without driving the coach.
Try to eliminate the fuel delivery problem. Once that's proven not to be the issue, let us know and we can try some electrical things. My guess is one of the above will be the culprit....with the carb my number one guess....Dennis
38,782 PostsLatest Activity: Sep 10, 2026
