j-d
Apr 21, 2016Explorer II
You didn't photo all of Jayco's label, but they're only going to parrot the tire pressure for max axle load. 4300 GAWR means 2150 per single tire or 65 PSI.
Please Please Please lower that front tire pressure! I'd like to have you drop it all the way to 50. Go 55 if you feel better, but LOWER that pressure.
Our front tire pressure should be 65. Tire shop set to 80. It tracked poorly till we went down the steep grade from the top of a high bridge in a cross wind. At that point we nearly lost it. Stopped on the side of the road and lowered to 70. Got our tracking back.
Air's Cheap, probably Free. Let some out! You can always put it back.
38,780 PostsLatest Activity: Aug 05, 2026
