j-d
Apr 21, 2016Explorer II
IAMICHABOD wrote:
If I have the numbers right and according to the Michelin chart with my 225/75r 16 my pressure should be 50psi with the front axle wt of 3880 or 1940 per tire. and the rear pressure at 60 psi with the weight of 7930 or 3965 per set of duals.
Is that correct?
YES, It IS!
Eric, If you still have the coach in the driveway, go ahead and adjust pressures in all six. Just be sure to observe Single/Dual. Pressure may be the end of the trail.
38,780 PostsLatest Activity: Aug 05, 2026
