DougE wrote:
If you get a cooling fan clutch, get one from GM - not an aftermarket - and store it in the as-installed orientation. If you start using oil (happens early on the 454) it's most likely valve guides. If you don't have an auxiliary trans cooler, get one - the largest plate-style cooler you can find.
RV does have a trans cooler. On my last trip Seattle - Huntington Beach, Ca and back I only consumed ~ 2/3qt oil. Not bad. Using Valvoline VR-1 Racing oil 10-30w with either Napa Gold filter or Mobil 1 Extended Performance filter.
The clutch seems to be working but I probably will swap it out with a GM before the trip. What is the most reliable method for checking if it is function as intended. With the engine cold and off I can spin it by hand but it does not freewheel easily and does not have a gritty feel indicating bad bearing/s.
