I_am_still_wayn
May 09, 2013Explorer
You obviously have something mechanically wrong with the starter system of the vehicle, and that should not in any way be associated with any of the RV systems. Therefore, any good automobile mechanic should be able to diagnose and repair the problem. I have learned long ago that if one has no idea what is wrong and how to fix it, paying an expert is far cheaper than "throwing parts" at the problem until the right solution is discovered by accident. Having said that, before you hire an expert, go through this check list:
1. Make sure the starting battery is adequate to do the job. Have it tested.
2. Clean all electric connections from the battery posts to the starter. Often, a corroded connection will not deliver enough electricity to work the starter.
3. Unless you have the skills to further test the system, then now hire an expert.
38,766 PostsLatest Activity: Jan 10, 2026
